Displays the current system memory and that of the specified process.
| name | Specifies the name of the process. |
| slotid | In a SummitStack, slotid specifies the slot number of the node in the stack topology. The value can be from 1 to 8. |
N/A.
Viewing statistics on a regular basis allows you to see how well your network is performing. When you keep simple daily records, you see trends emerging and notice problems arising before they cause major network faults. This way, statistics can help you get the best out of your network.
This information may be useful for your technical support representative if you experience a problem.
Depending on the software version running on your switch or your switch model, additional or different memory information might be displayed.
You can also use the show memory {slot slotid} command to view the system memory and the memory used by the individual processes.
When you issue the command with out any parameters:
The following example displays system memory and VRRP memory usage:
show memory process vrrp
The following is sample output from a Summit switch:
System Memory Information ------------------------- Total DRAM (KB): 262144 System (KB): 25852 User (KB): 96608 Free (KB): 139684 Memory Utilization Statistics ----------------------------- Process Name Memory (KB) ----------------------------- vrrp 11184
The following is sample output from a SummitStack:
Slot-1 stacK.4 # show memory process "aaa" System Memory Information ------------------------- Slot-1 Total DRAM (KB): 262144 Slot-1 System (KB): 25476 Slot-1 User (KB): 132276 Slot-1 Free (KB): 104392 Slot-6 Total DRAM (KB): 262144 Slot-6 System (KB): 25476 Slot-6 User (KB): 122820 Slot-6 Free (KB): 113848
----------------------------- Card Slot Process Name Memory (KB) --------------------------------------- Slot-1 1 aaa 2548 Slot-6 6 aaa 2440
This command was first available in an ExtremeXOS 11.1.
